Replacement of the roast chamber on any Kaffelogic Nano or Nucleus Link coffee roaster with a D or P prefix serial number.
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Hold the front panel steady while removing the plastic top/closure.
Pull away the front panel carefully.
Remove the last 2.5mm Hex screw securing the rear panel.
Pull up on the rear panel to remove it from the roaster.
Set the panels aside somewhere safe and bask in the beauty of your naked roaster.
Use a 2.0mm slotted screwdriver to remove the thermocouple wires from the PCB-A
Use needle-nose pliers to pull the roast chamber earth lead away from the earthing point.
Remove the roast chamber from the element chamber.
