Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement
  1. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Removing Front Panel Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Removing Front Panel Screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
    • Take care not to damage the buttons while maneuvering the front panel, with all six screws removed it may fall away.
  2. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Lift the closure: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Lift the closure: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the front panel steady while removing the plastic top/closure.
  3. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Removing the front panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull away the front panel carefully.
  4. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Removing the rear panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Removing the rear panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Removing the rear panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the last 2.5mm Hex screw securing the rear panel.
    • Pull up on the rear panel to remove it from the roaster.
  5. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Access granted: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Access granted: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Set the panels aside somewhere safe and bask in the beauty of your naked roaster.
  6. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the cable carrier: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the cable carrier: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the cable carrier: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2x 2.5mm Hex screws securing the cable carrier to the base.
    • Be careful not to lay the roaster on its front as the buttons can be damaged or broken off.
  7. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the mains wiring cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the mains wiring cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the mains wiring cover: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the terminal PCB cover and set it aside. This is held in with four small plastic clips at each corner.
  8. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Disconnect the mains input: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Disconnect the mains input: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Disconnect the mains input: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the mains cables. Marked an N (Neutral) and L (Live)
  9. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the earth tab: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the earth tab: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Remove the earth tab: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the mains earthing connector from the tab. Pliers can be used for this as it can be tight.
  10. Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Cable removed: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) Power Cable Replacement, Cable removed: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Your mains cable is now free, and ready for repair or replacement.
Kaffelogic
crwdns2935283:007/23/25crwdne2935283:0
46 crwdns2915208:0crwdne2915208:0
crwdns2935297:017crwdne2935297:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 41
