Replacement of the power cable on any Kaffelogic Nano or Nucleus Link coffee roaster with a D or P prefix serial number.
THIS GUIDE WILL NOT ALLOW YOU TO CHANGE YOUR ROASTER'S VOLTAGE SUPPORT!
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Hold the front panel steady while removing the plastic top/closure.
Pull away the front panel carefully.
Remove the last 2.5mm Hex screw securing the rear panel.
Pull up on the rear panel to remove it from the roaster.
Set the panels aside somewhere safe and bask in the beauty of your naked roaster.
Remove the 2x 2.5mm Hex screws securing the cable carrier to the base.
Remove the terminal PCB cover and set it aside. This is held in with four small plastic clips at each corner.
Disconnect the mains cables. Marked an N (Neutral) and L (Live)
Remove the mains earthing connector from the tab. Pliers can be used for this as it can be tight.
Your mains cable is now free, and ready for repair or replacement.
