Replacement of the USB daughterboard on any Kaffelogic Nano or Nucleus Link coffee roaster with a C or N prefix serial number.
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Hold the roaster steady while removing the plastic top/closure.
Remove the 4x 2.5mm Hex screws on the bottom of the roaster.
Pull away the front panel carefully.
Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
Pull upwards on the SSR signal connector to remove it.
Unplug your motor if your roaster is fitted with a connector, otherwise leave the connections in place.
Carefully pull on the ribbon cable to remove it.
Remove the 4x PH2 PCB screws.
Pull the board away from the chassis carefully, taking care with any wires still attached. We need to get to the back of the board.
Remove the 2x 1.5mm hex screws securing the plastic USB shroud.
Slide the plastic shroud away from the PCB
Pull away on the daughterboard to remove it from the main PCB.
