Replacement of an SSR on any Kaffelogic Nano or Nucleus Link coffee roaster with an A, B, C or N prefix serial number.
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Hold the roaster steady while removing the plastic top/closure.
Remove the 4x 2.5mm Hex screws on the bottom of the roaster.
Pull away the front panel carefully.
Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
Disconnect the SSR signal lead and motor from the PCB-A
Remove the 4x PH2 screws securing the gantry plate to the base.
Tip the stack forward to gain access to the SSR.
Use a PH2 screwdriver to remove the trigger lead.
Use a PH2 screwdriver to remove the two mains spade terminals.
Remove the 2x PH2 screws securing the SSR to the bottom of the gantry plate.
SSR can now be pulled out of the roaster and replaced.
