Replacement of the element on any Kaffelogic Nano or Nucleus Link coffee roaster with an A, B, C or N prefix serial number.
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Hold the roaster steady while removing the plastic top/closure.
Remove the 4x 2.5mm Hex screws on the bottom of the roaster.
Pull away the front panel carefully.
Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
Remove the 4x PH1 element chamber screws from the plastic bowl. (One screw not pictured)
Set the roast chamber aside but do not disconnect any wires.
Lift the element chamber up carefully to expose the element. Set this aside.
Lift up the element slightly and remove the support ring.
Use a flathead screwdriver to remove the element leads from the terminal block.
Pull the element leads through the fibreglass tubing to remove the element.
Double check the cable position, so that the screw is coming down on the wire and not the insulation of the element.
