KYVOL CYBOVAC E20 Wheel Assembly Replacement
  1. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KYVOL CYBOVAC E20 Wheel Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by laying the device on a flat surface with the logo facing up.
    • Flip the device over.
  2. KYVOL CYBOVAC E20 Wheel Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KYVOL CYBOVAC E20 Wheel Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 1 mm screws using a Phillips #00 screwdriver.
  3. KYVOL CYBOVAC E20 Wheel Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KYVOL CYBOVAC E20 Wheel Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cover.
  4. KYVOL CYBOVAC E20 Wheel Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KYVOL CYBOVAC E20 Wheel Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery.
    • Press down on the top of the white connector.
    • Remove the battery from the vacuum.
  5. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove both sweepers by pinching near the base of the brushes and pulling up.
  6. KYVOL CYBOVAC E20 Wheel Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 10 mm screws using a Phillips #00 screwdriver.
  7. KYVOL CYBOVAC E20 Wheel Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Wheel Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Wheel Assembly Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the wheel to detach the tensioning spring. This step requires you to first press down on the wheel, then detach.
    • Disconnect the wheel motor from the power supply.
    • Repeat the process for the other wheel.
  8. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove six 10 mm screws from the housing using a Phillips #00 screwdriver.
    • Open the gearbox.
  9. KYVOL CYBOVAC E20 Wheel Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove each gear.
  10. KYVOL CYBOVAC E20 Wheel Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KYVOL CYBOVAC E20 Wheel Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a J1 screw driver to remove two 6 mm screws from the gearbox.
Randall Morgan
crwdns2935283:007/13/23crwdne2935283:0
380 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-1, Harley Summer 2023 crwdns2935289:0IUPUI, Team 1-1, Harley Summer 2023crwdne2935289:0
IUPUI-HARLEY-SU23S1G1
crwdns2942667:0crwdne2942667:0 384
