KYVOL CYBOVAC E20 Main Motor Replacement
  1. KYVOL CYBOVAC E20 Main Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by laying the device on a flat surface with the logo facing up.
    • Flip the device over.
  2. KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 1 mm screws using a Phillips #00 screwdriver.
  3. KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cover.
  4. KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery.
    • Press down on the top of the white connector.
    • Remove the battery from the vacuum.
  5. KYVOL CYBOVAC E20 Main Motor Replacement, Wheel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove both sweepers by pinching near the base of the brushes and pulling up.
  6. KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 10 mm screws using a Phillips #00 screwdriver.
  7. KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the wheel to detach the tensioning spring. This step requires you to first press down on the wheel, then detach.
    • Disconnect the wheel motor from the power supply.
    • Repeat the process for the other wheel.
  8. KYVOL CYBOVAC E20 Main Motor Replacement, Main Motor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement, Main Motor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement, Main Motor: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nine 15 mm screws using a Phillips #2 screwdriver.
    • Remove the upper casing of the vacuum.
    • Remove the dust chamber.
  9. KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 10 mm screws using a Phillips #00 screwdriver.
    • Disconnect the plug.
    • Remove the front bumper.
  10. KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply pressure to each tab to remove the cover.
    • Remove the main brush.
  11. KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the vacuum so it is upright.
    • Disconnect the outer shell from the motherboard.
  12. KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single 10 mm screw using a Phillips #0 screwdriver.
    • Disconnect the motor from the motherboard and remove the main motor assembly.
    • Remove the four 6 mm screws using a Phillips #1 screwdriver.
    • Remove the gearbox cover.
  13. KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KYVOL CYBOVAC E20 Main Motor Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 6 mm screws using a Phillips #1 screwdriver to separate main motor from the housing.
Randall Morgan
crwdns2935283:007/13/23crwdne2935283:0
380 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-1, Harley Summer 2023 crwdns2935289:0IUPUI, Team 1-1, Harley Summer 2023crwdne2935289:0
IUPUI-HARLEY-SU23S1G1
Génial !
j'ai cherché depuis longtemps un tuto sur mon Kyvol E30 et celui-là est très bien fait !
(Le E30 est sensiblement le même que le E20, il a 1 side brush en moins, le reste est identique)
Mon E30 se mettait à faire un grand bruit, comme une vibration.
J'ai ouvert et démonté tout ce que je pouvais pour nettoyer et contrôler, après remontage, c'était pareil !
En fait le problème était au bout de la brosse, le roulement était coincé par un enroulement de cheveux (!) et le cabochon du roulement s'est usé, générant la vibration de la brosse ...
Merci pour votre aide bienvenue !
Kawaboy - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 422
