The Kyvol Cybovac E20 has a main rolling brush that may stop functioning over time from use. The brush should be taken out and cleaned, but if this does not work, the brush may be broken. If your vacuum is not cleaning well, use this guide to replace a broken main brush.
Turn the vacuum off and lay it on a flat surface.
Flip the vacuum over and identify the main brush compartment.
Take off the orange cover guarding the brush.
Remove the main brush from the vacuum by pulling it out.
Insert the new main brush.
I did everything cleaned and replaced with new parts and still not spinning
