The Kyvol Cybovac E20 contains a 3200mAh lithium-ion rechargeable battery. This guide should be used to replace your battery if your device:
- Fails charging
- Will not hold charge
- Will not turn on
Start by laying the device on a flat surface with the logo facing up.
Flip the device over.
Remove two 1 mm screws using a Phillips #00 screwdriver.
Lift the battery.
Press down on the top of the white connector.
Where can I find a compatible battery? Can I please have some links?
I am also looking for some links for a replacement battery
