KPN Arizona Comfort Replacement
  1. KPN Arizona Comfort Replacement, KPN Arizona Comfort: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KPN Arizona Comfort Replacement, KPN Arizona Comfort: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KPN Arizona Comfort Replacement, KPN Arizona Comfort: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the phone with one hand and apply a slight pressure on the battery lid with your other hand.
    • Now you can slide open the battery lid.
  2. KPN Arizona Comfort Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift out both batteries with a prying movement.
  3. KPN Arizona Comfort Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KPN Arizona Comfort Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KPN Arizona Comfort Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the following two Phillips #00 screws securing the back casing to the front.
  4. KPN Arizona Comfort Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KPN Arizona Comfort Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KPN Arizona Comfort Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to pry the front from the backside.
    • Start prying at the bottom and work your way around the device.
    • Do this for every 3 cm all around.
    • If you apply too much pressure or use a sharp tool, this might damage the casing.
  5. KPN Arizona Comfort Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KPN Arizona Comfort Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KPN Arizona Comfort Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the circuit board from the backside of the phone to the frontside of the phone by tilting it on the long edge
    • Make sure you do this gesture slowly and gently so the wires will not detach.
  6. KPN Arizona Comfort Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KPN Arizona Comfort Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KPN Arizona Comfort Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You are now facing the back side. Apply a little bit of pressure with the plastic opening tool on the back of the speaker so the the speaker can pop out.
    • The speaker is still attached with a wire, do not pull this.
  7. KPN Arizona Comfort Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KPN Arizona Comfort Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a soldering iron to heat up the solder connected to the electric wire.
    • When the solder is fluid, carefully pull the electric wire loose.
  8. KPN Arizona Comfort Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KPN Arizona Comfort Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replace the broken speaker of the phone and solder it back in place.
To reassemble your device, follow these instructions from step 6 in reverse order.
Maite
crwdns2935283:003/08/17crwdne2935283:0
131 crwdns2915208:0crwdne2915208:0
Delft University of Technology, Team S1-G19, Flipsen Spring 2017 crwdns2935289:0Delft University of Technology, Team S1-G19, Flipsen Spring 2017crwdne2935289:0
TUD-FLIPSEN-S17S1G19
crwdns2942667:0crwdne2942667:0 689
