These instructions will demonstrate how to remove/ replace the faceplate from the KDDI Kyocera A5521K.
Turn the phone over to expose the battery cover.
Apply pressure to the back of the battery cover to slide it down.
The battery cover is now separate from the phone.
Remove the battery by pushing it up and out from the bottom.
The battery, cover, and phone should now be separated.
Start by prying, with a metal probe, the black covers that are located by the pivoting joints of the phone/
Beneath those covers are the screws.
Remove the screws using a Y0 screwdriver.
Use the iPod pry tool to remove the outer screen.
Two screws are now visible.
Be careful not to crack the screen upon removal. It adheres strongly to the phone.
Use the Y0 screwdriver to remove the screws.
Use the iPod pry tool to loosen the faceplate from the phone.
Separate the faceplate from the phone.
To reassemble your device, follow these instructions in the reverse order.
