crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Insert the key cap puller into the cracks around the keycap.
Twist the tool around the bottom of the keycap.
Hold the keyboard down, and pull on the keycap slowly.
Pull up as straight as possible.
Proceed to remove the surrounding keycaps.
Flip the keyboard over so that the bottom is facing upward.
Slip an opening pick beneath the warranty sticker.
Proceed to pull the sticker off to reveal the hole.
Use a Phillips #1 Screwdriver to remove the 10 mm screw.
Slip an opening tool into the cracks at the indicated points.
Pry open carefully.
Flip the keyboard so that the keys are facing upward.
Grab the sides of the top case and pull up gently.
Separate the plate from the bottom case slightly.
Reach within and remove the daughterboard cable.
Turn the plate over.
Locate the pins for the key switch.
crwdns2935267:0crwdne2935267:0Desoldering Pump$3.99-
Desolder the pins with a soldering iron and a desoldering pump.
Repeat until the pins freely move inside the wells without heat.
Wedge two opening tools under the key switch.
Pull up gently.
Insert a new key switch into the well with pins corresponding to that of the PCBs.
Solder the pins onto the PCB ensuring the solder stays within the wells of the pins.
