KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement
  1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the key cap puller into the cracks around the keycap.
    • Twist the tool around the bottom of the keycap.
    • Hold the keyboard down, and pull on the keycap slowly.
    • Pull up as straight as possible.
    • Force required to pull a keycap may vary from soft to heavy.
  2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Proceed to remove the surrounding keycaps.
  3. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the keyboard over so that the bottom is facing upward.
    • Slip an opening pick beneath the warranty sticker.
    • Proceed to pull the sticker off to reveal the hole.
  4. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 Screwdriver to remove the 10 mm screw.
  5. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slip an opening tool into the cracks at the indicated points.
    • Pry open carefully.
  6. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the keyboard so that the keys are facing upward.
    • Grab the sides of the top case and pull up gently.
  7. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the plate from the bottom case slightly.
    • Reach within and remove the daughterboard cable.
  8. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the plate over.
    • Locate the pins for the key switch.
    • All the key switches are labeled with their ASCII designation.
  9. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Desoldering Pump
    $3.99
    • Desolder the pins with a soldering iron and a desoldering pump.
    • Repeat until the pins freely move inside the wells without heat.
    • Placing the soldering iron too close to the PCB may damage it.
  10. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge two opening tools under the key switch.
    • Pull up gently.
    • If the key switch appears to be immovable, consider repeating step 9.
  11. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a new key switch into the well with pins corresponding to that of the PCBs.
  12. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Solder the pins onto the PCB ensuring the solder stays within the wells of the pins.
    • Ensure the pins do not freely move after soldering.
    • Ensure that there is no solder connecting the two pins, as this can possibly cause a short circuit.
To reassemble your device, follow these instructions in reverse order starting at step 7.
Kenny Nguyen
crwdns2935283:007/05/20crwdne2935283:0
268 crwdns2915208:0crwdne2915208:0
York University, Team S1-G40, Allen Summer 2020 crwdns2935289:0York University, Team S1-G40, Allen Summer 2020crwdne2935289:0
YORK-ALLEN-SU20S1G40
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 1,991
