If the water heater is calcified or does not heat properly, it must be replaced. This procedure is shown here.
Remove all attachments: water tank, drip tray, aroma lid
Turn the machine so the back is facing toward the front.
The Jura sign must be removed. Turn it a few millimeters counterclickwise.
Remove the Jura sign.
Ich musste bei einer Impressa Z9 das Emblem gegen den Uhrzeigersinn drehen um es zu lösen.
Behind the Jura sign are two screws with an oval head. They have to be removed.
These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit for their removal. If the right bit is not available, it could be done with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!!
Hi there - really trying to find the tool to use for this. Please advise. Is there a link to it that I can buy?
Push the back down a bit and then remove it.
Pull the right side panel- as seen looking to the frontpanel - backwards and take it off.
In Schritt „5“ fehlt der Hinweis auf die noch zu entfernende Schraube unten am vorderen Teil der Seitenwand.
Remove the Torx T15 screw on the front wall of the side panel.
In the side part there is a lid over the brew group. The lid is fastened at the top with two oval head screws. Remove those to remove the lid.
With the cover removed the brew group becomes visible
Ich verstehe nicht, wie man die beiden Linsenkopfschrauben entfernt
Man braucht halt das Ovalkopfbit, z.B. von iFixit. Eventuell geht es mit einer Zange oder einem selbstgebauten Werkzeug.
VauWeh -
This step shows how to remove the top cover
Remove the powder tray and all coffee beans.
The cover is fastened with three Torx T15 screws. Those are easily visible under the covers as well as the small cover on the left back side.
Remove the two Phillips screws on the bean container and remove the bean container.
Lift the cover upwards.
Pull the left side panel backwards to take it off.
Here is one of the two water heaters removed.
A resistance measurement gives an indication of whether the heater is defective. Pull off one of the spade connectors. If the resistance is infinity or zero, then everything is clear... it should be in the 40 - 50 ohm range. But there could also be a short circuit from the heater to the metal housing, here the resistance must actually be infinite.
To check whether the heater is limed, you have to detach the two pressure hoses and blow into them. That has to go very easy.
Loosen the Torx T15 screw on the lid over the instant hot water heater.
Remove the lid. The two instant hot water heaters become visible.
The support of the instant water heater is fastened with a single, slightly recessed screw. Unscrew this Torx T15 screw.
Pull out the support of the water heater. It is still locked in at the top.
Unscrew the screw on the heater to be replaced. Watch the lock nut on the back.
Carefully remove the connectors on the sensor cables. For assembly, remember which sensor is connected to the red wire pair and which to the green wire pair.
Gently remove the water heater. It is still connected by hoses and wires.
Remove the cable shoes from the water heater connections.
Remove both Torx T25 screws from the brackets on the thermal fuses. Remove the thermal fuses.
Remove the Torx T25 screw from the eyelet of the yellow / green ground cable. Detach the cable.
The thermosensor may stay. If it is defective (the machine then reports Error 4), it has to be replaced
Now only the hoses are connected. They are attached with clips.
The clips are easy to open and close: attach a pair of pliers as shown in the photo and squeeze them together. The clamping plate falls out immediately and releases the clamping ring, which can then be compressed with the pliers and pushed away.
When the clips are open, the hose can be pushed off with some force.
Repeat the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Anyone know if these two water heaters have the same model name and if there’s a part number got it? My Jura Impressa Z9 started leaking out the bottom right heater after a botched service, and the weld completely snapped off..
Jura sells two versions of heaters, one for steam, one for hot water. I don't know, if they are interchangeable.
VauWeh -
