Jura Impressa S Model Transformer replacement
  1. Jura Impressa S Model Transformer replacement, How to open a Jura Impressa S model cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Impressa S Model Transformer replacement, How to open a Jura Impressa S model cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Always remove the power cord from the wall outlet.
    • Lift out the coffee tray
    • Remove the lid sealing the coffee bean container
    • Remove all of the coffee beans you can possibly remove.
    • Pull the adjuster of the coffee bean grinder straight up
    • Remove the four T15 Torx screws
    With the Impressa XS 90 there is an additional ground beans funnel that needs to be removed that hides two of the four torx screws
    Ian Channing - crwdns2934203:0crwdne2934203:0
  2. Jura Impressa S Model Transformer replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Impressa S Model Transformer replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cup heat plate.
    • It can be opened like a book.
    • Below the cup heat plate there are three more T15 Torx screws. Remove them.
  3. Jura Impressa S Model Transformer replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The top cover is now free. Lift ´er up and set ´er aside.
    With the Impressa XS 90 there is an additional cover above the grinder that has wires glued to it that prevents you from taking the top completely off.
  4. Jura Impressa S Model Transformer replacement, Jura Impressa S model backpanel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jura Impressa S Model Transformer replacement, Jura Impressa S model backpanel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jura Impressa S Model Transformer replacement, Jura Impressa S model backpanel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • The backpanel is secured with two proprietary screws with oval head. They seem to be rivets, but in fact are screws. The only purpose is, to keep us out of our own devices. You can remove them using an oval drive bit. (Part of some IFixit tool collections or available at a Jura provider or iFixit). In a pitch try needle nose pliers. Here a DIY guide.
    • Remove the two oval head screws on the lower edge of the backpanel.
    • Lift the panel up.
  5. Jura Impressa S Model Transformer replacement, Right side panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jura Impressa S Model Transformer replacement, Right side panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jura Impressa S Model Transformer replacement, Right side panel: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two Torx T15 screws at the bottom of the side panel.
    • Remove the Torx T15 screw on the front bottom right.
    • Remove the Torx T15 on the right underside of the front access door. Flip the door open a few inches.
  6. Jura Impressa S Model Transformer replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • A metal plate rests loosely on the top of the side panel and holds the rotation sensor in place. Note the position of the plate. Simply lift the plate upwards.
    • When reassembling, make sure that the sheet metal is put back in exactly the same way.
    • First lift the side panel away a little at the bottom, then lift it out at the top.
  7. Jura Impressa S Model Transformer replacement, Pump housing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the Torx T15 screw that holds the control board in place.
    • First lift the board a few millimeters up and then a few centimeters out of the machine. Watch out for the many cables.
    • Pull the silicone hose off the pump.
  8. Jura Impressa S Model Transformer replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Impressa S Model Transformer replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The pump support is like a drawer that can be pulled out to the rear. Two latches hold it in place on the left and right.
    • Insert a flat-blade screwdriver into the slots on the left and right and press the latches upward. At the same time, try to pull out the pump support to the rear.
    • It may sit a little tightly, but it will come loose.
  9. Jura Impressa S Model Transformer replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Impressa S Model Transformer replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pay attention to the diaphragm regulator when pulling it out. You have to push it up a bit so that the whole pump housing can slide out.
    • These components are now easily accessible and can be seen clearly in the second picture:
    • Power transformer
    • Drip tray sensors
    • Pump
    • Diaphragm regulator
    • Electromagnet for the drain valve
  10. Jura Impressa S Model Transformer replacement, Transformer: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two gray (230 V) and the two white flat plugs (15 V) from the transformer.
    • Lift the transformer out of the pump housing.
    • To check the transformer, you can first measure the resistances: at the 15 V terminals (secondary) it should be about 1 ohm, at the 230 V terminals (primary) about 100 ohms.
    • You can also apply an AC voltage of about 20 V on the 230 V (primary) side, then you should measure about 1.4 V on the 15 V (secondary) side. Do not swap the primary and secondary sides, otherwise you could get dangerously high voltages.
Work through the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0shinglecrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
258 220 crwdns2915208:0crwdne2915208:0
crwdns2935297:0293crwdne2935297:0
The right voltage ist 15 V. I don't know, what happens if you use 16.5 V. I personally would not dare to do so. Perhaps you can buy a used one, all transformers of Jura and many other brands use exact this model.
https://www.ebay-kleinanzeigen.de/s-anze...
VauWeh - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 2,309
