The transformer can break, especially if water drips on it from above. You should definitely eliminate leaks at the heaters. A typical error is when the machine can be switched on, the solenoid valve clicks loudly several times, but the brew group does not move and then "Error 8" (brew group not positioning) appears in the display.
Note: In these instructions, the top and right covers are removed. This is not difficult and makes the repair easier. However, it is not absolutely necessary. You can also just remove the back and get started.
Lift out the coffee tray
Remove the lid sealing the coffee bean container
Remove all of the coffee beans you can possibly remove.
Pull the adjuster of the coffee bean grinder straight up
Remove the four T15 Torx screws
Remove the cup heat plate.
Below the cup heat plate there are three more T15 Torx screws. Remove them.
The top cover is now free. Lift ´er up and set ´er aside.
crwdns2935267:0crwdne2935267:0iFixit Precision 4 mm Screwdriver Bit$2.99
The backpanel is secured with two proprietary screws with oval head. They seem to be rivets, but in fact are screws. The only purpose is, to keep us out of our own devices. You can remove them using an oval drive bit. (Part of some IFixit tool collections or available at a Jura provider or iFixit). In a pitch try needle nose pliers. Here a DIY guide.
Remove the two oval head screws on the lower edge of the backpanel.
Lift the panel up.
Remove the two Torx T15 screws at the bottom of the side panel.
Remove the Torx T15 screw on the front bottom right.
Remove the Torx T15 on the right underside of the front access door. Flip the door open a few inches.
A metal plate rests loosely on the top of the side panel and holds the rotation sensor in place. Note the position of the plate. Simply lift the plate upwards.
First lift the side panel away a little at the bottom, then lift it out at the top.
Unscrew the Torx T15 screw that holds the control board in place.
First lift the board a few millimeters up and then a few centimeters out of the machine. Watch out for the many cables.
Pull the silicone hose off the pump.
Insert a flat-blade screwdriver into the slots on the left and right and press the latches upward. At the same time, try to pull out the pump support to the rear.
It may sit a little tightly, but it will come loose.
Pay attention to the diaphragm regulator when pulling it out. You have to push it up a bit so that the whole pump housing can slide out.
These components are now easily accessible and can be seen clearly in the second picture:
Power transformer
Drip tray sensors
Pump
Diaphragm regulator
Electromagnet for the drain valve
Disconnect the two gray (230 V) and the two white flat plugs (15 V) from the transformer.
Lift the transformer out of the pump housing.
Work through the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934883:0shinglecrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Can i use 16.5 v transformer?
The right voltage ist 15 V. I don't know, what happens if you use 16.5 V. I personally would not dare to do so. Perhaps you can buy a used one, all transformers of Jura and many other brands use exact this model.
