Your fully automatic coffee machine makes very loud noises when grinding the coffee beans?
When making coffee, does the coffee only come out in drips?
Then you may have a problem with the grinder of your Jura Impressa F50 fully automatic coffee machine.
These instructions are intended to help you get access to the grinder of your fully automatic coffee machine in order to service it or to replace it completely.
It consists of a total of 3 parts: opening the machine, removing the grinder and reassembly.
Remove the drip pan, tray and container for used coffee,...
... the water tank, ...
and the aroma protection cover.
One hurdle: the back is attached with four special oval-head screws. They look like rivets. To remove them, you need an oval-head bit. In a pinch, you can also use a good pair of pliers.
Remove the two T15 Torx screws from the coffee machine housing cover.
Remove the top cover of the coffee machine.
Remove the panel from the right side.
Remove the lock washer on the axle for grinding degree adjustment using pliers.
Remove the grinding degree adjustment axle by using pliers to pull it upwards.
Remove the 2 screws on the bean container of the coffee machine with the Torx T10 screwdriver.
Remove the pinion for the grinding degree adjustment.
Remove the 3 screws attaching the grinding mill attachment to the grinder with the Torx T10 screwdriver.
Disconnect the first connector (black cable) from the plug-in connector attached to the bottom of the grinder.
Separate the second (white) cable attached to the grinder from the housing of the plug-in connector.
Remove the grinder to clean or replace it.
Reinstall the new or repaired grinder into the coffee machine.
Reconnect the grinder to the connectors. Make sure to place the connectors in the correct place.
Now set the grinder back into its correct position
Reattach the 3 screws for grinding mill by fastening them to the inserted grinder with the Torx T10 screwdriver.
Reinsert the bean container into the coffee machine.
Fasten the two screws we remove from the bean container earlier with the Torx T10 screwdriver.
Reinsert the axle for grinding degree adjustment.
Use pliers to reseat the safety washer.
Reinstall the left side panel.
Place the housing cover back on the coffee maker.
Use the Torx T15 screwdriver to tighten the 2 countersunk screws on the housing cover.
Using the oval head wrench, tighten the 4 oval head screws on the back of the machine.
Replace the water tank,
the drip tray with drip tray, pulp tray and pulp container,
and place the aroma protection cover back on.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2935103:0crwdne2935103:0
Bij de demontage van de maalmolen
Zijn er drie grotere kogeltjes plus veren.
Er is nog een kleiner veertje en een kleiner kogeltje dat ik zag tijdens de demontage.
Ik heb geen idee waar die kleine kogel en veer uit gekomen is.
Kan iemand dat vertellen
