Jura Ena Micro 9 Replace the top cover
  1. Jura Ena Micro 9 Replace the top cover, Jura ENA micro 9 opening procedure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the power plug!
    • Remove all attachments, such as the water reservoir, coffee grounds drawer, and bean compartment lid.
    • Remove all coffee beans.
  2. Jura Ena Micro 9 Replace the top cover, Top covers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Ena Micro 9 Replace the top cover, Top covers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The top covers do not necessarily have to be removed for all repairs. However, it is indispensable for thorough cleaning. It may be easier to loosen the top covers if the side panels are removed first. The process is somewhat tricky.
    • Pry the central ventilation cover up.
  3. Jura Ena Micro 9 Replace the top cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jura Ena Micro 9 Replace the top cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jura Ena Micro 9 Replace the top cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to press in on both sides of the marked area. Then the front cover around the on / off switch is unlocked. You can then lift it up at the front and pull it out at an angle.
    • If the side openings for the spudger cannot be found, the model is slightly different. With this version you have to insert the spudger into the gap between the front panel and cover, about 3 cm from the edge and then push it firmly towards the center to unlock. At the same time, lift the cover a little at the front.
  4. Jura Ena Micro 9 Replace the top cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Ena Micro 9 Replace the top cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip up the front cover.
    • Remove the cover. In the model with the side holes, you can pull them out at an angle to the front. With the other model, you have to push it back a little to unhook it, then lift it up.
  5. Jura Ena Micro 9 Replace the top cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is what it looks like when the two lids are gone. A lot of dirt built up.
  6. Jura Ena Micro 9 Replace the top cover, Side panels: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The side parts are pushed out to the rear. However, they are secured with two screws and a lock at the top and a wedge-shaped catch on the sides.
    • Unscrew the two T15 Torx screws that secure the side panels at the top.
  7. Jura Ena Micro 9 Replace the top cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jura Ena Micro 9 Replace the top cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jura Ena Micro 9 Replace the top cover: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The lock is located under the Jura badge on the back. Turn it counterclockwise about 20 degrees, then you can remove it.
    • Unfortunately, this one is very stuck. Nothing helped with this device, no suction cup or stiff adhesive tape. Here it is opened with a somewhat more rustic method:
    • Two small holes were drilled a few millimeters deep, then two small screws were screwed in. The badge could finally be turned and removed with a pair of pliers.
  8. Jura Ena Micro 9 Replace the top cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jura Ena Micro 9 Replace the top cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jura Ena Micro 9 Replace the top cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This is what it looks like underneath. The lock is secured with an oval head screw. It looks like a rivet. To open you need a special oval head bit, in an emergency you can use pliers.
    • Remove the oval head screw.
    • Push the lock firmly upwards as far as possible.
  9. Jura Ena Micro 9 Replace the top cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The side parts are held at the top and bottom with three hooks each. Therefore, they have to be moved backwards to detach them. However, they are secured against shifting with wedge-shaped notches at the front. The next step shows how they can be solved.
    • The notches must be lifted out of the openings. They are located on both sides at the top and bottom about 1.5 cm from the edge and 7 cm from the front edge.
    • This is what the wedge-shaped notches look like
  10. Jura Ena Micro 9 Replace the top cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jura Ena Micro 9 Replace the top cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jura Ena Micro 9 Replace the top cover: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the machine on its side.
    • Pry the side panel about 7 cm from the front edge, about 3 mm high. This will cause the catch to come out of its opening. Use a strong tool, preferably one made of plastic.
    • Position of the wedge-shaped notch: 7 cm from the front edge, 1.5 cm from the top or bottom edge.
    • Leave the tool in place. Insert an opening pick 7 cm from the front edge so that the wedge-shaped notch can no longer engage in its opening. Pull out the tool.
    • In the same way, insert another opening pick on the opposite edge.
    • Now both notches are free and the side part can be moved in the next step.
  11. Jura Ena Micro 9 Replace the top cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the side panel firmly backwards. It may get stuck a bit and you need to use a plastic pry tool to help.
    • Take off the side panel and set it aside.
    • Repeat for the other side panel.
  12. Jura Ena Micro 9 Replace the top cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jura Ena Micro 9 Replace the top cover: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jura Ena Micro 9 Replace the top cover: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Release the catches on the top of the inner cover.
    • Flip the inner cover down and lift it out. The brew group becomes now visible.
    • The cover is not present on all models.
    • The third picture shows a view of the other side.
  13. Jura Ena Micro 9 Replace the top cover, Top cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three Torx T15 screws that secure the top cover.
    • Carefully remove the top cover. Start at the back. The top cover is stuck quite tightly under the front cover, carefully remove it bit by bit.
Work through the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
289 385 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
Repair is War on Entropy crwdns2935289:0Repair is War on Entropycrwdne2935289:0
Community
crwdns2931471:031crwdne2931471:0
crwdns2935297:01 552crwdne2935297:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 704
