Follow this guide to open the casing of a Jura J5.
Remove the water tank and the drip tray. Remove all coffee beans from the storage container.
Flip open the lid of the bean compartment.
Unscrew the two slotted screws inside the bean compartment. The screws have a rubber washer and will not come out completely.
Remove the bean compartment.
crwdns2935267:0crwdne2935267:0iFixit Precision 4 mm Screwdriver Bit$2.99
The top cover is fastened with oval head screws. Unscrew them.
Also remove the two oval head screws underneath the ground coffee compartment lid.
Now you can pry up the top cover all around.
Remove the top cover. This often requires a little force.
Turn the device with the back facing you.
Turn the Jura label a few degrees counterclockwise. If it's hard to do, use a small suction cup.
Remove the Jura label.
Underneath the label you will find two Torx T15 screws. Remove them.
Carefully pull the top of the chrome cover slightly outwards, then push it down and put it aside.
Remove the Torx T15 screw on the side panel with the water tank.
Pull the right side panel slightly towards the back.
Remove the side panel.
Pull the left side panel slightly towards the back and remove it.
Follow the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
