Joy-Con ZL Switch Replacement
crwdns2869540:0crwdne2869540:0: 16K
19
128
439
16,472
crwdns2955950:0crwdne2955950:0: 4
crwdns2960004:03crwdne2960004:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 3
crwdns2959974:03crwdne2959974:0
crwdns2955944:0crwdne2955944:0: 9 - 20 crwdns2931279:0crwdne2931279:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
The metal cover holding the ZL switch together had broken off the switch and jammed the control
    1. Joy-Con ZL Switch Replacement, Unscrew the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the Y00 Tri-Point screwdriver, remove four M1.4 x 5mm screws to loosen the hard plastic back of the Joy-Con.
      • After the screws are removed, lift the cover to reveal the inside of the Joy-Con and locate the ZL button.
      • The button exposed could either be the ZL or the ZR depending on which Joy-Con needs to be fixed.
    2. crwdns2935267:0crwdne2935267:0
      • Use tweezers to lift the ZL button a little then pull upwards to get it back into place.
      • Once the button is back in place, place the hard cover back on the Joy-Con and screw it back on.
      • Click the button a couple times to ensure that it's back in place and working.
      • This may either be the ZL or ZR button depending on the Joy-Con being fixed.
    3. Joy-Con ZL Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Resume gameplay!
    1. Joy-Con ZL Switch Replacement, The problem part: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Joy-Con ZL Switch Replacement, The problem part: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • This tiny piece of metal had come off the small pcb and ribbon cable. In doing so it had jammed the switch.
      • Use the guide for un-jamming ZL switch, to remove the case screws, the top cover and the ZL switch and springs.
    2. Joy-Con ZL Switch Replacement, Splitting it apart: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Joy-Con ZL Switch Replacement, Splitting it apart: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Joy-Con ZL Switch Replacement, Splitting it apart: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Having removed the plastic button and 2 springs you uncover the switch and holding screw.
      • Remove the holding screw.
    3. Joy-Con ZL Switch Replacement, Pop out the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Joy-Con ZL Switch Replacement, Pop out the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the battery out of the battery chassis tray.Use a plastic splitter if necessary.
      • Do not remove the sticky tape underneath as this is unnecessary. It does not effect the repair.
    4. Joy-Con ZL Switch Replacement, Remove the battery tray: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Joy-Con ZL Switch Replacement, Remove the battery tray: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the 4 screws holding down the inner battery support chassis. This exposes the switch connector to the pcb.
      • Note the bottom left screw in this picture is shorter than the others and needs to be put back in the correct aperture.
    5. Joy-Con ZL Switch Replacement, Pulling the plug on the problem....: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pull on the ribbon cable to remove the plug from the socket.
      • Insert plug on new ribbon cable & switch.
      • You may need to push in the plug with plastic tweezers. Take care not to damage the cable.
    6. Joy-Con ZL Switch Replacement, Putting it back together: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Replace batters chassis tray and screw back into place. Note to put back the shorter screw into the correct hole.
      • Fold battery back into place. Gently push down to get the battery stuck back to the tape.
      • Adjust the ribbon cable to ensure it is not trapped. Place the switch over the alignment pin and screw down the retaining screw.
    7. Joy-Con ZL Switch Replacement, Yippee it works!: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Joy-Con ZL Switch Replacement, Yippee it works!: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Joy-Con ZL Switch Replacement, Yippee it works!: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Put the two springs back on their retaining pins and push the button back into place.
      • It should click into place and when you push on the button you should hear the switch click.
      • Fold the cover back over and check there are no trapped wires before screwing back the 4 screws on the cover to complete the repair.
Robin Razzell
crwdns2935283:009/04/13crwdne2935283:0
394 crwdns2915208:0crwdne2915208:0
This doesn’t really cover the removal of the ZL/ZR Buttons.
It is good for removing the actual button on the mother board, but not for removing the plastic button on the remote.
OreoDestroyer93 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 128
crwdns2936753:030crwdne2936753:0 439
crwdns2959996:0crwdne2959996:0 16,472
