This guide will show you how to replace the battery in your Joy-Con controller.
There are a few minor differences between the left and right Joy-Cons. These steps apply to both Joy-Cons.
crwdns2936621:0crwdne2936621:0
Remove the four Tri-Point Y00 screws from the back panel of the Joy-Con.
Insert an Opening Pick into the bottom edge of the back panel (opposite the shoulder buttons).
Slowly slide the flat edge of your Opening Pick up the side of the Joy-Con.
Open the Joy-Con like a book, with the charging rail facing away from you.
Use a Spudger to gently pry the battery connector from its socket on the motherboard. This will keep the Joy-Con from powering on during the repair.
Beim wiedereinstecken des Akkus hat sich für mich bewährt die Flache seite des Spudgers etwas zwischen die beiden Akkukabel zu stecken.
Außerdem sollte man darauf achten, dass wenn man wie in den Bildern zu sehen den Akkustecker von der Platine entfernt nicht ausversehen die Bauteile von der Platine bricht die unmittelbar vor dem Stecker sind
Hallo Sontha,
danke für die Anmerkung. Viel Spaß mit deiner Switch!
Viele Grüße!
Insert an Opening Pick between the battery and the Joy-Con housing.
Gently pry out the battery, which is lightly taped in place.
thx for making this process ez and affordable.
definitely saved the environment of dumping 4 perfectly reusable joy-cons.
Thank you Ifixit, I changed my battery fairly easy. Your guide has been very helpful!
Easy-peasy. Joy-Con now works while disconnected again. Thanks, ifixit!
What width of tape should I buy for this? The link to the store for the double sided-tape shows four choices (1, 2, 4 or 8mm). The kit we can buy comes with a tape card, but I need to change four batteries, and buying four kits would be a waste.
crwdns2935229:075crwdne2935229:0
crwdns2947412:012crwdne2947412:0
Bonjour, après avoir suivi les étapes tout fonctionne ,SAUF la recharge … à savoir également que je me suis trompé dans la commande de la nouvelle batterie, celle-ci étant d'une capacité plus faible
Bonjour Ced ! Nous sommes désolés de l’apprendre. Avez-vous essayé de calibrer la batterie ? Veuillez prendre contact avec notre service client (support@ifixit.com pour la boutique américaine ou eustore@ifixit.com pour la boutique européenne et française) en indiquant votre numéro de commande. Ce sera un plaisir de vous porter assistance !
Bei mir ging beim roten Joy Con oder Akku nicht mehr, ich hab ihn jetzt auseinandergeschraubt, das Kabel vom Akku gelöst und wieder eingesteckt.
als ich alles zusammengebaut habe ging er. Es war wahrscheinlich nur das Kabel was nicht richtig drin war.
Hello, i'm unsure what to do now but I have replaced my battery but my switch still doesn't show the presence of my right joy-con. I opened up the joy-con while connected to the switch and the battery is only charging at 1.2v (without the battery the pins are the same) could it be the charging rail? Any tips would be appreciated. Thanks!
Mir fiel der linke Joy Con bei einer wilden Play Session auf den Boden und funktioniert nicht mehr. Dank Anleitung und iFixit Set konnte ich den Joy Con öffnen und das Kabel des Akkus wieder fest einstecken - Problem gelöst. Danke ifixit!
What type of connector is on the battery.is jst molex dupont Jr futaba or something?can you tell me?
close up video of your hands are hairy like a guy's
What is the little mat with the ifixit logo on it that came with the kit? I thought it was a mini magnetic mat, but I tried to get a screw to stick to it and it didn't. It's very flexible and looks like it should be peelable, but I didn't want to attempt this on the off chance it is something else.
As far as the guide itself, it was very easy to follow and worked perfectly for me. Thank you!
I believe that is replacement tape or adhesive for the battery, incase yours came off of the joycon case with the battery!
Vielen Dank! Meine zwei Joy Cons haben nun wieder frische Akkus! :)
Hi! I recently preformed this repair successfully, but now the buttons on the rail do not work. However the rail itself still works and connects to the switch. There are no broken ribbon cables or loose connections to my knowledge. Could it be the way the ribbon cables are positions inside the casing, maybe I placed them back in wrong? Any help would work, thanks!
I really enjoyed the video and the written instructions. Thanks
