Jeep Differential Fluid Replacement
crwdns2936621:0crwdne2936621:0
  1. Jeep Differential Fluid Replacement, Remove the bolts from the differential cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jeep Differential Fluid Replacement, Remove the bolts from the differential cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a socket wrench or an air gun to remove the bolts from the differential cover
    • source
    • Make sure to keep the metal tag with the gear ratio and axle type information
    • source.
  2. Jeep Differential Fluid Replacement, Drain the differential fluid: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place a bucket under the differential
    • Use a hammer to tap the cover and let the fluid drain out
    • Then, remove the cover
    • source.
  3. Jeep Differential Fluid Replacement, Check for damage: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jeep Differential Fluid Replacement, Check for damage: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While the cover is off, inspect the ring gear, pinion gear, and spider gears for any damage or missing/broken teeth
    • source
    • Make sure the vehicle is in neutral so you can spin the gears
    • Check for metal shavings or sludge at the bottom of the differential
    • source.
  4. Jeep Differential Fluid Replacement, Clean the differential housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use brake parts cleaner to clean the inside of the housing
    • Wipe it down with paper towels and let it dry
    • source.
  5. Jeep Differential Fluid Replacement, Clean the differential cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clean the cover with brake parts cleaner, both inside and outside
    • Make sure to remove any old RTV or gasket material from the mating surface
    • source.
  6. Jeep Differential Fluid Replacement, Apply RTV: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jeep Differential Fluid Replacement, Apply RTV: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a bead of RTV sealant around the mating surface of the differential cover, making sure to go around each bolt hole
    • source
    • Use a dry finger to spread the RTV evenly over the surface
    • source
    • Let it sit for a minute to become tacky.
  7. Jeep Differential Fluid Replacement, Reinstall the differential cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the cover with the differential housing and press it into place
    • Reinstall the bolts and the metal tag you removed earlier, tightening them in a criss-cross pattern to ensure even pressure on the gasket
    • source.
  8. Jeep Differential Fluid Replacement, Fill the differential with gear oil: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After letting the RTV dry for a short time, remove the fill plug and fill the differential with gear oil until it starts to spill out of the fill hole
    • source
    • Replace the fill plug and clean up any excess oil.
eCuration
crwdns2935283:005/19/17crwdne2935283:0
449,322 crwdns2915208:0crwdne2915208:0
crwdns2935297:0252crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,459crwdne2935297:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 1,288
