If you need to remove the back cover of your UltraTab C855 for replacement or further maintenance, this guide is for you!
Remove the 4 exterior screws using a Phillips #000 Screwdriver .
Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
