Follow this guide to effectively remove and replace the camera of Jazz UltraTab. The procedure takes 20-30 minutes. However, if the guide is followed accurately, the task will be accomplished with minimal damage to the device.
First step is to remove the screws. You can find the screws on top and bottom edge of the device.
Remove the back panel of the device using an opening tool.
Upon removing the back panel, place the device screen down on the table.
There are two screws holding the camera. Remove them.
The next step is to lift the Touch Screen Digitizer (the black piece).
Slide out the Data Strip.
Detach the camera, and remove it.
Replace the camera, and reassemble.
