Jabra Speak 510 USB Connector Replacement
    • I then decided to assume the risk and fix it myself. Before doing that, I purchased the smallest pack I could find of USB connectors to use in the repair, and I ended up with 5 connectors (which was good, as I would see a little down the road).
    • I took a leap of faith when I CUT the cable (ugh! No way back now!). I then started to peel the cable and strip the tiny-and-extremely-delicate wires that were inside it (4 wires and a cable mesh, together with some fabric stripes).
    • With a soldering iron, I spread some soldering tin at the end of each wire (as well as over the cable mesh), and then did the same with the terminals of the USB connector.
    • I then welded each wire to the appropriate terminal (as I thought, and this is the plot twist!), according to Googled images of USB connectors, that indicated the sequence of wires as Ground/Data+/Data-/VCC (+5V). In all diagrams Google spit back on me, that sequence was represented by black/green/gray/red.
    • I closed the connector, plugged it into the USB port on my laptop, opened a track and... nothing. Instead of throwing music through the Jabra speaker, the laptop was playing the track through its own speakers, COMPLETELY ignoring my precious Jabra Speak(!!!!).
    • A few seconds later, a message appeared, stating that the USB device was not recognized by Windows and therefore was [logically] disconnected. Tried again. Nothing. Again. Nothing...
    • On my way to despair (very close to it, quite frankly), I teared the original Jabra connector (the one that was cut loose as part of my baptism of fire in this process), and found out that the color sequence was a little different...
  1. Jabra Speak 510 USB Connector Replacement, The plot twist: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • ... instead of black/green/gray/red, Jabra decided to use black/grey/green/red -- which means I switched green and gray (data+ and data-), and apparently that's why the device was not recognized by Windows.
  2. Jabra Speak 510 USB Connector Replacement, Things get better and better: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Speak 510 USB Connector Replacement, Things get better and better: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Speak 510 USB Connector Replacement, Things get better and better: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • I pick another connector (only three left, after that!), peeled the wires again, welded them into the terminals in the new sequence (black/green/gray/red), plugged my Jabra Speak into the USB port of my laptop, open a track and... voilà! Coltrane almost brought tears to my eyes (this time for a mix of emotional and technical reasons).
    Is the correct sequence - black/green/gray/red?
    In step 8 you mentioned "... instead of black/green/gray/red, Jabra decided to use black/grey/green/red -- which means I switched green and gray (data+ and data-), and apparently that's why the device was not recognized by Windows."
    I am getting ready to repair my Jabra 510 and want to do correctly.
    Thansk!
    mmitsch - crwdns2934203:0crwdne2934203:0
    Hi mmitsch,
    if jabra did not issue a new release of its speaker, that should be the winning sequence. I can also take a better picture of the final color sequence and post it here (the one I took is too dark).
    Joao Sidou -
    • Questions, after this [more than repairing] learning process: Why on Earth Jabra uses a different color sequence (not just different colors, but simply the same colors but on a different sequence, other than the standard) for their wiring? I don't know the answer to this.
    • Why am I spending another 45 minutes writing this text? That's easy...
    • I just want to share this experience with those who love Jabra speakers but hate the way some providers (like Jabra, if I am not mistaken) try to confuse those who dare to repair their products at home, instead of taking them to a [very] expensive repair shop or even dumping such products in a garbage can. Hope you like it.
    Hi, Very thankful to you on your post, it helped me a lot to rebirth to my Jabra.
    My one, USB is not working. Now its working for charging connected with bluetooth.
    Nagalla - crwdns2934203:0crwdne2934203:0
    Hi Nagalla,
    Great! Good to know it was useful! In my opinion, cabling is definitely an opportunity for improvement for this great product.
    Cheers!
    Joao Sidou -
Joao Sidou
crwdns2935283:004/18/23crwdne2935283:0
235 crwdns2915208:0crwdne2915208:0
Thank you. I fixed my Jabra 510 thanks to this guide!
Luca - crwdns2934203:0crwdne2934203:0
Great to know it was useful!!
Joao Sidou -
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 1,580
