  1. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back plate and the grey foam underneath.
  4. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T6 Torx Screwdriver, remove the four (4mm) screws.
  6. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
  7. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the white adhesive to desolder the connections underneath.
    • Desolder the wires connected to the motherboard.
    • You can find soldering tips in the How To Solder and Desolder Connections guide.
    • Keep track of where the wires are connected. When re-assembling you will have to connect the wires in the correct spot.
crwdns2935229:05crwdne2935229:0
Jordan Murphy
crwdns2935283:002/16/16crwdne2935283:0
746 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-3, Harley Spring 2016 crwdns2935289:0IUPUI, Team 2-3, Harley Spring 2016crwdne2935289:0
IUPUI-HARLEY-S16S2G3
Great walk-through... thanks
Walaa Maher - crwdns2934203:0crwdne2934203:0
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
Thomas Sprenger - crwdns2934203:0crwdne2934203:0
Hello
Where I can buy the motherboard replacement?
Regards
Lobo Gris - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 79
crwdns2942667:0crwdne2942667:0 8,441
