This guide explains how to replace one of the 3 main speakers in the Freeway, however all 3 speakers are removed using this guide and the process is identical. Be sure the device is completely powered off before continuing.
Remove the rubber pads from the bottom of the device using the spudger.
Remove the eight 6mm T9 screws.
Gently lift the front panel off of the device and carefully rest it to the side.
Gently lift the speaker out of the device using the spudger.
Desolder the two wires connecting to the speaker.
This guide is missing something. It is titled Speaker Replacement not just removal. Useful information to complete the replacement of a faulty speaker would include where to find a replacement part or at least a part number to search for. Removing the speaker without replacing it with another is of little use. But thank you for your time and effort.
