This guide will show you how to replace the battery on the Freeway.
Remove the rubber pads from the bottom of the device using the spudger.
Remove the eight 6mm T9 screws.
Gently lift the front panel off of the device and carefully rest it to the side.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the rubber gasket using tweezers.
Remove the five 6mm T6 screws connecting the circuit board to the rear panel.
Remove the microphone from microphone slot.
Carefully use the plastic opening tool to lift the circuit board up.
Desolder the three wires connecting the battery.
Please refer to the soldering technique guide for instructions on desoldering and soldering.
Where will I get the replacement battery. Any source in India if possible....
crwdns2947412:011crwdne2947412:0
Hey Alec,
Why does your guide to replacing the battery in the Jabra Freeway say "no parts required"?
This would be much more useful if you provide a part number and source(s) for the replacement battery. And then maybe show removing the old battery and installing the new one.
Hi,
Does anyone knows a source for the compatible battery. Since Jabra Freeway battery has 3 wires, cannot find it online. I could find compatible batteries from China websites but they were with 2 wires.
I am sourcing replacement batteries for the jabra freeway should be in the end of april
any luck finding a replacement battery yet for this device???
I’m looking for the batteries, 3 of them, right now 2018 06.
Hey Alec, why don’t you reply ……. why don’t you help people …….. we all need to know about this battery thingy…. or we can put any three terminal battery in it ………. please help us for God sake
Is there a way to bypass the battery and have the device powered by the car charger all the time?
I found a slightly thicker battery, but it should fit. Li-Po 3.7V 103443 https://tiny.pl/tgkvb
How about you actually show us the battery & it's specifications? or is this just a trolling exercise?
I used this battery:
https://smile.amazon.com/gp/product/B071...
It works. It’s a little long so you have to remove some plastic to make it fit, but it works. I took me an hour. Much of this was removing the plastic. The little wires from the two small high frequency speakers were the most pain and limited the work space for removing the T6 torx screws but it worked out.
The battery that robin28 posted worked for me. I did have to remove some plastic.
