Jabra Freeway Battery Replacement
  1. Jabra Freeway Battery Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Freeway Battery Replacement, Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Freeway Battery Replacement, Front Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
  2. Jabra Freeway Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Freeway Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Freeway Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
    Why not show us which 2 are under the foam padding?
    Doug - crwdns2934203:0crwdne2934203:0
  3. Jabra Freeway Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Freeway Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Freeway Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jabra Freeway Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber gasket using tweezers.
  5. Jabra Freeway Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jabra Freeway Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 6mm T6 screws connecting the circuit board to the rear panel.
  6. Jabra Freeway Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Freeway Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Freeway Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the microphone from microphone slot.
  7. Jabra Freeway Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Freeway Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Freeway Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully use the plastic opening tool to lift the circuit board up.
  8. Jabra Freeway Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the three wires connecting the battery.
    • Please refer to the soldering technique guide for instructions on desoldering and soldering.
    Where will I get the replacement battery. Any source in India if possible....
    Prasanna N - crwdns2934203:0crwdne2934203:0
Alec Wilson
crwdns2935283:010/19/16crwdne2935283:0
741 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-8, Catania Fall 2016 crwdns2935289:0UMass Dartmouth, Team 4-8, Catania Fall 2016crwdne2935289:0
UMASSD-CATANIA-F16S4G8
crwdns2947412:011crwdne2947412:0
Hey Alec,
Why does your guide to replacing the battery in the Jabra Freeway say "no parts required"?
This would be much more useful if you provide a part number and source(s) for the replacement battery. And then maybe show removing the old battery and installing the new one.
Glenn C - crwdns2934203:0crwdne2934203:0
Hi,
Does anyone knows a source for the compatible battery. Since Jabra Freeway battery has 3 wires, cannot find it online. I could find compatible batteries from China websites but they were with 2 wires.
Devesh Singh Senwal - crwdns2934203:0crwdne2934203:0
I am sourcing replacement batteries for the jabra freeway should be in the end of april
scuba - crwdns2934203:0crwdne2934203:0
any luck finding a replacement battery yet for this device???
chcastle - crwdns2934203:0crwdne2934203:0
I’m looking for the batteries, 3 of them, right now 2018 06.
DavidNS - crwdns2934203:0crwdne2934203:0
Hey Alec, why don’t you reply ……. why don’t you help people …….. we all need to know about this battery thingy…. or we can put any three terminal battery in it ………. please help us for God sake
Amer Tufail - crwdns2934203:0crwdne2934203:0
Is there a way to bypass the battery and have the device powered by the car charger all the time?
Krishna Sukumaran - crwdns2934203:0crwdne2934203:0
I found a slightly thicker battery, but it should fit. Li-Po 3.7V 103443 https://tiny.pl/tgkvb
Krzysztof Michałowski - crwdns2934203:0crwdne2934203:0
How about you actually show us the battery & it's specifications? or is this just a trolling exercise?
haider alrekabi - crwdns2934203:0crwdne2934203:0
I used this battery:
https://smile.amazon.com/gp/product/B071...
It works. It’s a little long so you have to remove some plastic to make it fit, but it works. I took me an hour. Much of this was removing the plastic. The little wires from the two small high frequency speakers were the most pain and limited the work space for removing the T6 torx screws but it worked out.
robin28 - crwdns2934203:0crwdne2934203:0
The battery that robin28 posted worked for me. I did have to remove some plastic.
Benny Rios - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,194
