Jabra Elite 85h Speaker Replacement
  1. Jabra Elite 85h Speaker Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Speaker Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Speaker Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
    Hi sir, I think your guide is incomplete. Do you have the opportunity to bring a sequel?
    Oğuzhan Sancak - crwdns2934203:0crwdne2934203:0
    The battery is under the left earcup.
    NOT the earcup into which you plug the USB cable.
    Not sure why the demo asks you to disassemble the right earcup...
    Jimbo - crwdns2934203:0crwdne2934203:0
    These instructions could use some work! There is no need to disassemble both sides as the battery is under the left ear cup only.
    kelly1 - crwdns2934203:0crwdne2934203:0
    I have just disassembled mine, Jabra Elite 85h, model OTE100. The cushions (as described in this step) can not be removed. If that's the case, The foam in the center has to be removed to access the speaker screws. Undoing the screws will split the headphone in half, releasing the pad together with the speaker. This will uncover the rest of the components
    Besides, I agree with the rest of the comments - If you're after the battery there is no need to disassemble the right headphone as the battery resides in the left
    bystrzak14 - crwdns2934203:0crwdne2934203:0
    This is very easy. I just finished mine. You dont need special tools as a tweeser will pull the wire connection apart. The cushions will come off and are replaceable. Do just the left one. Pull it apart like you mean it. Do have a small piece of thick double-sided tape on hand. The AOLIKES 3.7v 850mAh battery from amazon works but the wire is a bit short to orient it like the original. Just don’t press it in place until the circuit board is screwed in place. All I can say now is that it’s charging.
    Lastly, I’ve learned from experience that if you’re using metal screws in plastic, when reassembling turn counter clockwise until you hear a click. Thats when they are aligned properly and you’re less likely to strip the thread.
    CJ ? - crwdns2934203:0crwdne2934203:0
  2. Jabra Elite 85h Speaker Replacement, Speaker: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Speaker Replacement, Speaker: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Speaker Replacement, Speaker: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The foam inserts and backing tape are very delicate. Take your time when removing them, and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous steps for the other side, removing the foam inserts with care.
  4. Jabra Elite 85h Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the previous step for the other side, removing the four T6 screws.
  6. Jabra Elite 85h Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
    Battery is behind left speaker ONLY.
    Đorđe Radomirović - crwdns2934203:0crwdne2934203:0
    and after ? how to pop up the speaker from his green/yellow support ?
    Kev Delyon - crwdns2934203:0crwdne2934203:0
Matt Gardiner
crwdns2935283:003/15/23crwdne2935283:0
351 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-4, Petersen Spring 2023 crwdns2935289:0UMass Dartmouth, Team 3-4, Petersen Spring 2023crwdne2935289:0
UMASSD-PETERSEN-S23S3G4
Thanks a lot man, I was having some issues with my left side for a while. I assumed it was bad connection since it would return depending on the position and sometimes on non-ANC setup. I just tightened those screws and now it works fine. Cheers.
Alex Fernandes - crwdns2934203:0crwdne2934203:0
Hi, doughter overturned the speaker. Now the device no longer switches on. can this be fixed again?
Thanks fit your Help.
Regards
Oliver Viboh - crwdns2934203:0crwdne2934203:0
Where can I get replacement speakers. I know it is 40mm in diameter but what is the ohm and other specifications?
Çağdaş Son - crwdns2934203:0crwdne2934203:0
Disculpe donde se ubica esque tengo mi jabra elite 85h y no retiene la carga de bateria
Lorenzo Rivera - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 119
crwdns2942667:0crwdne2942667:0 2,327
