Jabra Elite 85h Bluetooth Module Replacement
crwdns2942287:0crwdne2942287:0If you are having problems connecting to your Jabra Elite 85H headphones there could be a problem with the Bluetooth module. Follow this guide to correctly disassemble the headsets and repair the module. This guide takes you step by step on how to do it.
crwdns2944105:0crwdne2944105:0
Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
Unscrew and remove the four T6 screws holding the speaker in place.
Tilt the headphones over so that the speaker tilts out of the plastic holder.
Repeat for both sides.
Remove the two screws holding the upper and lower circuit boards in place.
Remove the two attached circuit boards from the headphone housing.
De-solder Bluetooth Module from control board to replace.
Kurwa nauczcie się wszystko się odpina nic nie trzeba lutować a wtyczka biała normalnie wychodzi tylko klej trzeba usunąć a ta czarna wtyczka ją do góry ciągniesz
But where could one get this Bluetooth Module? Is it only available for Jabra workers?
