Jabra Elite 85h Bluetooth Module Replacement
  1. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
  2. Jabra Elite 85h Bluetooth Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Bluetooth Module Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Bluetooth Module Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The foam inserts and backing tape are very delicate, take your time when removing them and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Bluetooth Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Bluetooth Module Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jabra Elite 85h Bluetooth Module Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat previous steps on other side.
  4. Jabra Elite 85h Bluetooth Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Bluetooth Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
  6. Jabra Elite 85h Bluetooth Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jabra Elite 85h Bluetooth Module Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws holding the upper and lower circuit boards in place.
  7. Jabra Elite 85h Bluetooth Module Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jabra Elite 85h Bluetooth Module Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two attached circuit boards from the headphone housing.
    • De-solder Bluetooth Module from control board to replace.
    Kurwa nauczcie się wszystko się odpina nic nie trzeba lutować a wtyczka biała normalnie wychodzi tylko klej trzeba usunąć a ta czarna wtyczka ją do góry ciągniesz
    Ludwig Fiołkowy - crwdns2934203:0crwdne2934203:0
Ryan Callaghan
crwdns2935283:003/13/23crwdne2935283:0
917 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-4, Petersen Spring 2023 crwdns2935289:0UMass Dartmouth, Team 3-4, Petersen Spring 2023crwdne2935289:0
UMASSD-PETERSEN-S23S3G4
But where could one get this Bluetooth Module? Is it only available for Jabra workers?
sarita sulkakoski - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,028
