JVC GR-D72U LED Light Replacement
  1. JVC GR-D72U LED Light Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JVC GR-D72U LED Light Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate button on bottom of camera.
    • Slide button to the right.
  2. JVC GR-D72U LED Light Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery towards the bottom of the camcorder while lifting battery .
  3. JVC GR-D72U LED Light Replacement, Lateral Function Port Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JVC GR-D72U LED Light Replacement, Lateral Function Port Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JVC GR-D72U LED Light Replacement, Lateral Function Port Panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
    • Remove the 3.1 mm screw.
    • Remove the three 5.3 mm screws from the back of the camera.
  4. JVC GR-D72U LED Light Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From the bottom of the camera remove the following four screws:
    • 5.3 mm
    • 3.1 mm
    • 5.1 mm
    • 3.5 mm
  5. JVC GR-D72U LED Light Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the small plastic opening tool to remove the blue side cover piece.
  6. JVC GR-D72U LED Light Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3.1 mm screw on top of the camera, closest to the LCD monitor.
    • Remove the 5.4 mm screw next to the snapshot button.
  7. JVC GR-D72U LED Light Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3.1 mm screw next to the USB and DV inputs.
  8. JVC GR-D72U LED Light Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull apart both halves of the camera to reveal the inner components.
  9. JVC GR-D72U LED Light Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the cable locks to the up-position and pull both cables connecting the lateral function port panel to the rest of the camera.
    • Insert the cables from the new port panel into their inputs and flip the locks to the down position.
    • It is easier to use tweezers when inserting the cable but not required.
  10. JVC GR-D72U LED Light Replacement, Cassette Holder: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From the inside of the camera remove these six screws.
    • 3.3 mm
    • 3.6 mm
    • 3.1 mm
    • 4.3 mm
    • 4.3 mm
    • 3.7 mm
  11. JVC GR-D72U LED Light Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the three cables from the circuit board.
  12. JVC GR-D72U LED Light Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • From the top of the camera remove the two 3.1 mm screws securing the lens to the camera frame.
    • From the bottom of the camera remove the 3.2 mm screw next to the battery release switch.
    • Remove the 9.1 mm screw next to the menu and volume control label.
  13. JVC GR-D72U LED Light Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lens cap housing.
    • Remove the two 3.1 mm screws from the inside of the camera.
  14. JVC GR-D72U LED Light Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the plastic cover piece next to the silver light button.
    • Remove the 3.1 mm screw securing the lens to the circuit board.
    • Remove the two 3.3 mm screws from underneath the battery port.
  15. JVC GR-D72U LED Light Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the cassette holder and circuit board by lifting it out of the camera frame.
    • Remove the two 3.6 mm screws.
    • Remove the two 1.8 mm screws then the plate.
    • If you are following this guide to replace the LED light or microphone you do not need to follow this step or the next step.
  16. JVC GR-D72U LED Light Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six cables (one is underneath the metal plate) connecting the cassette holder to the circuit board.
    • To unplug two of the cables you must first pull the lock tabs out (towards the cable) then remove the cable.
  17. JVC GR-D72U LED Light Replacement, LED Light: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws securing the microphone housing and camera operation buttons to the frame with the following sizes:
    • 4.3 mm
    • 3.1 mm
    • 4.2 mm
  18. JVC GR-D72U LED Light Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4.3 mm screw on the bottom of the camera frame.
    • Remove the two 4.3 mm screws above the LED securing the microphone housing to the frame.
  19. JVC GR-D72U LED Light Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the cassette holder to reveal a 2.4 mm screw on the bottom of the camera and remove it.
    • Make sure the camera operation buttons are positioned completely outside of the camera frame.
    • Gently lift the microphone housing from the front-bottom side of the camera and remove it from the frame.
  20. JVC GR-D72U LED Light Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JVC GR-D72U LED Light Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2.3 mm screws holding down the LED chip and remove the chip.
    • Ignore this step if you are following this guide for the microphone.
Jonah Powers
crwdns2935283:009/28/17crwdne2935283:0
437 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G2, Nance Fall 2017 crwdns2935289:0USF Tampa, Team S2-G2, Nance Fall 2017crwdne2935289:0
USFT-NANCE-F17S2G2
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 342
