JBL Xtreme battery replacement
  1. JBL Xtreme battery replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 8.4 V battery pack for the JBL Extreme.
  2. JBL Xtreme battery replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the screws and remove the shell.
  3. JBL Xtreme battery replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery pack by unscrewing the 8 screws. Unplug the battery pack. Drill a hole. Seal holes with hot glue for air-tightness.
  4. JBL Xtreme battery replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme battery replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Solder the positive wires together, and solder the negative wires together. Use a 5.5 x 2.1 hollow DC connector for the power supply. Insulate the cable ends (Heat shrink wrap, electrical tape, etc.)
  5. JBL Xtreme battery replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Battery, 8.4 Volt. 13200mAh 8.4V Rechargeable Battery Pack Charger for Bicycle Light-XML-T6
  6. JBL Xtreme battery replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solarstorm 2S2P 18650 Battery Case.
    • 4xPanasonic NCR18650B 3,7V 3400mAh=14400 mAh
    • + 5V USB ON/OFF Button
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Bert
crwdns2935283:006/27/17crwdne2935283:0
253 crwdns2915208:0crwdne2915208:0
hi
step 2: unscrew the screws …. thats th point, where are the screws. the body looks like glued.
stephan dingsda - crwdns2934203:0crwdne2934203:0
Hi.
Don’t ask me, because I have this guide only translated not created. Try to contact the author on de.ifixit.com. I have translated it so, that I tried to don’t change the original text.
Martin
Martin Kubica - crwdns2934203:0crwdne2934203:0
I didn’t get it quite clear: is there a original battery replacement or an improvised one? I am interested in replacing mine but I didn’t find the battery.
Chris Fotu - crwdns2934203:0crwdne2934203:0
Hi.
See the comment higher.
Martin Kubica
WTF?!? Don’t do this. Buy a replacement battery online, and swap it out. Don’t drill holes, add glue, and try to cram in some battery that isn’t built for it!
fixit4 - crwdns2934203:0crwdne2934203:0
Yeah, what the hell is it. Just use that youtube video of that company that sells batteries (it should come up as one of the first on youtube). Extra info:
1. Use a proper fit phillips screwdriver; apparently the screws are very tightly put in and you could damage the screwheads.
2. There are apparently nine and not 8 screws there were he mentions it; one should be under some tape.
3. Apparently that outer cover is glued pretty hard on the plastic. Be aware of that and use the best tool you can find that is plastic and maybe more than one, so you will avoid damaging anything.
4. Apparently the original battery has some type of glue put on the connector, which makes it harder to get the connector out. Try using plastic and not metal there as well, as you might damage the board it's connected to.
Note: I said apparently as this is what I read in comments. You might find it's different when you do it but keep these things I mind so you are prepared. And again: this guide is indeed bullshit.
saxofoonles -
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 106
crwdns2942667:0crwdne2942667:0 30,070
