This guide will offer sound advice to help you remove and replace your JBL Xtreme's speakers.
            Locate the seams next to the 'feet' on the bottom side of the device.
            Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
            For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
            For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
            Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
            Once the screws have been removed, the bass radiator will easily lift free.
            With the radiators removed, locate the ribbon cable indicated in the image.
            First, unscrew the eight 12.93mm Phillips head screws indicated in red. These screws hold the two primary speakers in place.
            Next, remove the four 9.75mm Phillips head screws for the two smaller speakers indicated in blue and the speakers should lift out with little effort.
crwdns2935229:015crwdne2935229:0
crwdns2947412:011crwdne2947412:0
My speaker won't hold a charge for more then 2 hours? Why is that thanks
where can i buy the speaker of jbl xtreme?
Where can I get replacement speakers for my JBL?
Where can I get s replacement speaker
etesme -
where can I get parts to fix the speaker?
