This guide will help you replace a damaged cover and access other components.
Locate the seams next to the 'feet' on the bottom side of the device.
Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
Yes, the fact needs to be added that two screws need to also be removed to get the cover off. One side snaps off but the other is attached with two screws.
%#*@^@. I ripped the plastic things apart. Should have red the comments first. &&^&.
same here ;D just grabbed some glue and hope it will stick :D
Vorsichtig die Kante hochhebel, wo der Reissverschluss ist. Da ist die Hülle gesteckt. Die andere Seite hat Schrauben die man lösen sollte. Ansonsten zerstört man zu Beginn die Befestigung der einen Seite.
For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
Hello Where can I get a replacement cover?? Mine is damaged.
Did u ever find it they sell the covers?
Careful with this step, my JBL Xtreme case was also held in place by wo little srews !
It feels like you are “breaking” the cover, but in fact it seems to have a kind of “bending point” near the top of the cover by the exterior controls. Watch for the two screws to remove.
There is two screws holding the cover at its other end beside the plastic snaps
%#*@! broke one of the little snaps near the 2 screws. still holds tight though.. be careful when pulling them out. Also, don’t forget the screws
Die beiden Schrauben befinden sich jeweils neben den Füßen des Geräts. (Ein Foto von den beiden Schrauben wäre sehr hilfreich!)
crwdns2935229:014crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Can you fix my cover on speaker
where can I find a new cover for xtreme 2, if possible in black?
If you find a place to buy a cover let me know
you forgot about 2 screws
zapomniałeś o śrubach osoby które o tym mogły nie wiedzieć mogły urwać plastikowy haczyk który utrzymuje przód
