This guide will help you replace a damaged cover and access other components.
Locate the seams next to the 'feet' on the bottom side of the device.
Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
crwdns2935229:014crwdne2935229:0
Can you fix my cover on speaker
where can I find a new cover for xtreme 2, if possible in black?
If you find a place to buy a cover let me know
you forgot about 2 screws
zapomniałeś o śrubach osoby które o tym mogły nie wiedzieć mogły urwać plastikowy haczyk który utrzymuje przód
