crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Use a spudger or other prying tool to gently pry open the middle section of the speaker.
To open the case, open the front side gently rotating along the hinge.
Once you have the speakers exposed like in the image, at the bottom part you will snap open the back end piece of the grill still attached.
Using a Phillips #00 screwdriver, remove the four 12.9 mm screws securing the faulty speaker.
Lift the speaker out of its housing and you will see two cables connecting the speaker. Pull the speaker towards you and each of the cable connectors away from you.
Do the same for both cables.
Jep u open it wrong way. I broken My speaker Plastic attachment so i need extra work whit wrong opening way. I can sent u a some pic whit this.
Happened to me too. Please include the images about the screw from the other repair manual (for the battery)
