JBL Wave Beam Case Disassembly
    1. JBL Wave Beam Case Disassembly, Heat up the case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Open up your case and remove the earbuds. Prepare a heat gun at around 150℃, and gently heat up the front part of the case, around where the LED is.
    2. JBL Wave Beam Case Disassembly, Insert a plastic pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Wave Beam Case Disassembly, Insert a plastic pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Now try to insert an opening pick into the seam as shown. If you can't get it in, try heating the case more or using a different pick.
      • Slide the pick around the edge of the case until it reaches the back, next to the hinge part. You can apply more heat here if this is too difficult.
      • Repeat with a second opening pick, going round the other side. The second image shows what your case should now look like.
    3. JBL Wave Beam Case Disassembly, Lift out the internals: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a plastic tool to lift up the internals as shown
      • If this is too difficult, you might want to use a third pick, and pry around the area under the LED.
    4. JBL Wave Beam Case Disassembly, Remove the electronics: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Wave Beam Case Disassembly, Remove the electronics: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • You should now have removed the outer case. Remove the two Phillips #0 screws next to the exposed USB port.
      • Pull the motherboard directly upwards. Be gentle here, as it is still connected to the glued-down battery
      • Use a plastic tool to pry out the battery, it is attached to the case with a sticky pad. If you have isopropyl alcohol, apply some underneath the battery to loosen the adhesive.
    5. JBL Wave Beam Case Disassembly, Desolder the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The battery is connected to the motherboard with either 3 or 2 solder pads. Use a soldering iron and flux to remove all of them, being careful not to cause any shorts.
      • Solder the black and red wires of your new battery to GND and BATT on the motherboard, respectively. If there is a third wire (temperature sensor) solder it to the NTC pad.
Chris P. Croutonne
crwdns2935283:007/19/25crwdne2935283:0
1,238 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 150
crwdns2936753:030crwdne2936753:0 623
crwdns2942667:0crwdne2942667:0 3,694
