If your having trouble with the charging port on your “JBL Tube 720BT Headphones this guide is the perfect guide for you
On our guide we will show you step by step on How to replace the charging port on the JBL tune 720BT Headphones.
First step we will start by prying off the back of the right ear cup using the “jimmy” tool.
Next we continue by removing the screws while holding down the board and takeout the cover.
Use the Jimmy to pry off the back cover of the left ear cup, revealing the battery.
Disconnect the battery by gently removing the red, white, and black wires from their socket.
Back on the right side, gently flip the board to reveal the charging port.
Set the board onto a comfortable position for the next step
Use a soldering iron to heat and remove the old port.
