JBL Pulse Speakers Replacement
  1. JBL Pulse Speakers Replacement, Button Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
    I used a heat gun here to heat the adhesive before I attempted to pry. Using heat, I was able to remove the circuit board with the rubber overlay still attached. Use common sense on how much heat to apply. Don’t melt the plastic or rubber. Perhaps 60ºC
    Michael Pitts - crwdns2934203:0crwdne2934203:0
  3. JBL Pulse Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the button board, exposing the attached cable.
    How can I get one of these to replace?
    St. Bre Dook - crwdns2934203:0crwdne2934203:0
  5. JBL Pulse Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
    Sir where is shop button board
    bhhed expose - crwdns2934203:0crwdne2934203:0
    Sir where is shop button board .
  6. JBL Pulse Speakers Replacement, Outer Casing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse Speakers Replacement, Outer Casing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse Speakers Replacement, Outer Casing: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
  7. JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
  8. JBL Pulse Speakers Replacement, JBL Pulse Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two black 9mm PH0 screws from outside of inner casing on each side.
    There are actually 5 screws to remove altogether. At least on my Pulse 1 there were. Two at the bottom, two at the top and the one in the center. The pic shows the one in the center and only one at the top.
    true mine too
    ayush ganvir -
  9. JBL Pulse Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse Speakers Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse Speakers Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your metal spudger to unhook the bracket holding the case together.
    • Pull apart the casing with your hands.
  10. JBL Pulse Speakers Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse Speakers Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove cables by pulling firmly.
  11. JBL Pulse Speakers Replacement, Speakers: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse Speakers Replacement, Speakers: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four black PH0 9mm screws.
    • The only thing still attaching the speakers is the wires to the soldering points. Cut wires at soldering points.
    • New speakers will have to be re-soldered to these wires.
    What is the speaker model, where to buy
    Kashwin Kumar - crwdns2934203:0crwdne2934203:0
    What is the speaker model and where to buy
    What is speakers modal nomber
    Kall - crwdns2934203:0crwdne2934203:0
Maxwell Busenbarrick
crwdns2935283:009/15/16crwdne2935283:0
1,353 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 18-6, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 18-6, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S18G6
crwdns2935297:013crwdne2935297:0
crwdns2947412:08crwdne2947412:0
Hi,
Thanks for your guide. Where did you obtain replacement speakers?
heaton.steven - crwdns2934203:0crwdne2934203:0
Hi. Even I would like to know a good replacement/ substitute speaker for this. Thanks
Vishakh A V - crwdns2934203:0crwdne2934203:0
Hi.
Even I would like to know where I can find a replacement or an alternate speaker..
what is the speaker specification that I can buy for replacement?
rbalagr - crwdns2934203:0crwdne2934203:0
Could you please share any links to buy these spare speakers ..Thanks in advance ☺️
deepak gupta - crwdns2934203:0crwdne2934203:0
Where can i get these speakers ?
Joydeep Halder - crwdns2934203:0crwdne2934203:0
Do you know if the battery can be replaced? If so, do you know which battery model it uses? Thanks in advance for sharing this guide!
Gabriel Nunes Campos - crwdns2934203:0crwdne2934203:0
where did you get the JBL pulse replacement speakers? Pls share the source or links or shop where I get these speakers to repair my pulse.
Maverick - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 7,611
