JBL Pulse Speakers Replacement
  1. JBL Pulse Speakers Replacement, Button Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
  3. JBL Pulse Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the button board, exposing the attached cable.
  5. JBL Pulse Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
  6. JBL Pulse Speakers Replacement, Outer Casing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse Speakers Replacement, Outer Casing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse Speakers Replacement, Outer Casing: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
  7. JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
  8. JBL Pulse Speakers Replacement, JBL Pulse Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two black 9mm PH0 screws from outside of inner casing on each side.
  9. JBL Pulse Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse Speakers Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse Speakers Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your metal spudger to unhook the bracket holding the case together.
    • Pull apart the casing with your hands.
  10. JBL Pulse Speakers Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse Speakers Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove cables by pulling firmly.
  11. JBL Pulse Speakers Replacement, Speakers: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse Speakers Replacement, Speakers: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four black PH0 9mm screws.
    • The only thing still attaching the speakers is the wires to the soldering points. Cut wires at soldering points.
    • New speakers will have to be re-soldered to these wires.
Maxwell Busenbarrick
crwdns2935283:009/15/16crwdne2935283:0
1.377 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 18-6, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 18-6, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S18G6
crwdns2935297:013crwdne2935297:0
crwdns2947412:09crwdne2947412:0
Hi,
Thanks for your guide. Where did you obtain replacement speakers?
heaton.steven - crwdns2934203:0crwdne2934203:0
Hi. Even I would like to know a good replacement/ substitute speaker for this. Thanks
Vishakh A V - crwdns2934203:0crwdne2934203:0
Hi.
Even I would like to know where I can find a replacement or an alternate speaker..
what is the speaker specification that I can buy for replacement?
rbalagr - crwdns2934203:0crwdne2934203:0
Could you please share any links to buy these spare speakers ..Thanks in advance ☺️
deepak gupta - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 8,016
