JBL Pulse Motherboard Replacement
  1. JBL Pulse Motherboard Replacement, Button Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
    I used a heat gun here to heat the adhesive before I attempted to pry. Using heat, I was able to remove the circuit board with the rubber overlay still attached. Use common sense on how much heat to apply. Don’t melt the plastic or rubber. Perhaps 60ºC
    Michael Pitts - crwdns2934203:0crwdne2934203:0
  3. JBL Pulse Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the button board, exposing the attached cable.
    How can I get one of these to replace?
    St. Bre Dook - crwdns2934203:0crwdne2934203:0
  5. JBL Pulse Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
    Sir where is shop button board
    bhhed expose - crwdns2934203:0crwdne2934203:0
    Sir where is shop button board .
  6. JBL Pulse Motherboard Replacement, Outer Casing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse Motherboard Replacement, Outer Casing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse Motherboard Replacement, Outer Casing: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
  7. JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
  8. JBL Pulse Motherboard Replacement, JBL Pulse Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two black 9mm PH0 screws from outside of inner casing on each side.
    There are actually 5 screws to remove altogether. At least on my Pulse 1 there were. Two at the bottom, two at the top and the one in the center. The pic shows the one in the center and only one at the top.
    true mine too
    ayush ganvir -
  9. JBL Pulse Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your metal spudger to unhook the bracket holding the case together.
    • Pull apart the casing with your hands.
  10. JBL Pulse Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove cables by pulling firmly.
  11. JBL Pulse Motherboard Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all of the cables are removed, grip the motherboard and slide it out.
Maxwell Busenbarrick
crwdns2935283:009/15/16crwdne2935283:0
1,353 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 18-6, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 18-6, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S18G6
crwdns2935297:013crwdne2935297:0
Excelente, funcionó perfectamente la guia. Compré la bateria y el armado funcionó perfecto. Muchas gracias.
Angel Pérez - crwdns2934203:0crwdne2934203:0
my usb port is damaged. Do I have to replace the whole motherboarD?
dinosdabi - crwdns2934203:0crwdne2934203:0
Hey I need JBL pulse motherboard Where can I buy. Please help
kashyapvikas228vk1070301 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 9,629
