JBL Pulse LED Light Replacement
  1. JBL Pulse LED Light Replacement, Button Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse LED Light Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
    I used a heat gun here to heat the adhesive before I attempted to pry. Using heat, I was able to remove the circuit board with the rubber overlay still attached. Use common sense on how much heat to apply. Don’t melt the plastic or rubber. Perhaps 60ºC
    Michael Pitts - crwdns2934203:0crwdne2934203:0
  3. JBL Pulse LED Light Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse LED Light Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the button board, exposing the attached cable.
    How can I get one of these to replace?
    St. Bre Dook - crwdns2934203:0crwdne2934203:0
  5. JBL Pulse LED Light Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
    Sir where is shop button board
    bhhed expose - crwdns2934203:0crwdne2934203:0
    Sir where is shop button board .
  6. JBL Pulse LED Light Replacement, Outer Casing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse LED Light Replacement, Outer Casing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse LED Light Replacement, Outer Casing: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
  7. JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
  8. JBL Pulse LED Light Replacement, LED Light: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off LED light panel using a metal spudger.
Maxwell Busenbarrick
crwdns2935283:009/15/16crwdne2935283:0
1,353 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 18-6, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 18-6, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S18G6
crwdns2935297:013crwdne2935297:0
Were do I buy a Replacement led strip?
Jalen6988 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 3,502
