×4
crwdns2959928:0crwdne2959928:0 ↓When the lights are displaying improperly, usually replacing the LED lights will fix the problem.
Use a plastic opening tool to pry around the edges of the circular rubber panel.
Once the edges are loose, pull off the rubber button panel completely.
Use your plastic opening tool to pry the button board loose by lifting the edges.
Lift the button board, exposing the attached cable.
Pull black piece on top of socket away from board to loosen, then detach the cable.
Take out the four 9mm black PH0 screws from the top and bottom of the device.
Pull off cap by hand.
The outer casing can now be removed.
Remove the tape around the cables on the top of the device.
Remove the cables by lifting up on the black bracket and then pulling the cable out.
Pry off LED light panel using a metal spudger.
Were do I buy a Replacement led strip?
Jalen6988 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
