Often times when buttons have become unresponsive, a faulty button board may be the cause. In this guide we will show you how to access and replace the button board.
Use a plastic opening tool to pry around the edges of the circular rubber panel.
Once the edges are loose, pull off the rubber button panel completely.
Use your plastic opening tool to pry the button board loose by lifting the edges.
Lift the button board, exposing the attached cable.
Pull black piece on top of socket away from board to loosen, then detach the cable.
crwdns2935229:05crwdne2935229:0
