JBL Pulse 4 Charging Port Replacement
  1. JBL Pulse 4 Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off JBL Pulse 4 before starting any repairs.
    • Hold the power button for 3 plus seconds to power down the device.
  2. JBL Pulse 4 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Charging Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove each rubber end cap using an plastic pry tool.
    • Go around each end of the speaker slowly popping up a small section of the rubber cap at a time until there is a gap on all sides.
    • The cap can be easily removed by hand.
    • Do not use a metal object or you will scratch the casing or tear the rubber end caps.
  3. JBL Pulse 4 Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Charging Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the charging port cover using a plastic pry tool.
    • Remove the two Phillips head screws.
    • The charging port assembly will be revealed.
  4. JBL Pulse 4 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Charging Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the charging port assembly out of the casing.
    • Be careful and don't remove the assembly fully to avoid damaging the wires.
    • Carefully disconnect the two wires attached to the assembly.
  5. JBL Pulse 4 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now you can reassemble the speaker reversing the steps provided to take it apart.
Hank McDonough
crwdns2935283:003/18/24crwdne2935283:0
377 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Konn Spring 2024 crwdns2935289:0UMass Dartmouth, Team 2-2, Konn Spring 2024crwdne2935289:0
UMASSD-KONN-S24S2G2
crwdns2942667:0crwdne2942667:0 592
