JBL Pulse 4 Button Board Replacement
  1. JBL Pulse 4 Button Board Replacement, Casing Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off the device before doing any repairs.
    • Hold the power button for 3+ seconds to power down the device.
  2. JBL Pulse 4 Button Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove each rubber end cap using a plastic pry tool.
    • Go around each end of the speaker slowly popping up a small section of the rubber cap until there is a gap on all sides.
    • Remove the top by hand.
  3. JBL Pulse 4 Button Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the charging port cover using a plastic pry tool.
    • Remove the two 12.7 mm Phillips #1 screws.
    • Remove the charging port housing from the casing.
  4. JBL Pulse 4 Button Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the charging port connector by pulling the connector away from the port.
    • Disconnect the battery level indicator light by pulling the wire away from the lights.
  5. JBL Pulse 4 Button Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 8 mm Phillips #1 screws from the end of the speaker with the grill that says "JBL."
    • Remove the plastic piece where the 6 screws came out of.
  6. JBL Pulse 4 Button Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 9.5 mm screws using a Phillips #1 screwdriver.
  7. JBL Pulse 4 Button Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the speaker to the other end.
    • Use a pry tool to pry between the casing of the speaker and the internals.
    • Go around the entirety of this end of the speaker slowly prying apart the two pieces.
  8. JBL Pulse 4 Button Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The casing is now fully detached from the internal components.
    • You can now replace the outer casing of the speaker.
  9. JBL Pulse 4 Button Board Replacement, LED Light Display: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 4 Button Board Replacement, LED Light Display: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the speaker on the table with the button board side down.
    • Remove the three black 5 mm screws using a Phillips #1 screwdriver.
    • Remove the white casing by pulling it away from the button board.
  10. JBL Pulse 4 Button Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clip off the two zip-ties using the zip tie cutter.
  11. JBL Pulse 4 Button Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel each LED strip off of the speaker using an iFixit opening pick.
  12. JBL Pulse 4 Button Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four black 5 mm screws using a Phillips #1 screwdriver.
    • Remove the white plastic piece that is held in place by the screws.
  13. JBL Pulse 4 Button Board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the red/white cable from the white connection.
  14. JBL Pulse 4 Button Board Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the LED light display from the speaker.
  15. JBL Pulse 4 Button Board Replacement, Battery: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement, Battery: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement, Battery: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  16. JBL Pulse 4 Button Board Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the cable connecting the battery to the motherboard.
  17. JBL Pulse 4 Button Board Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Feed the wire out of the central housing unit.
    • Pull the battery out of the central housing unit.
  18. JBL Pulse 4 Button Board Replacement, Motherboard: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Pulse 4 Button Board Replacement, Motherboard: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers, gently unplug the three connections attached to the motherboard.
  19. JBL Pulse 4 Button Board Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the motherboard out of the frame.
    • The only connection the motherboard has to the frame now should be the soldered-on black wire.
  20. JBL Pulse 4 Button Board Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Pulse 4 Button Board Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder the wire from the motherboard.
    • Remove the motherboard from the speaker.
  21. JBL Pulse 4 Button Board Replacement, Button Board: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the black cable off the motherboard using cutters to remove the button board.
Ethan Zuziak
crwdns2935283:002/25/25crwdne2935283:0
73 crwdns2915208:0crwdne2915208:0
University of Kentucky, Team 1-6, Frey Spring 2025 crwdns2935289:0University of Kentucky, Team 1-6, Frey Spring 2025crwdne2935289:0
UKY-FREY-S25S1G6
crwdns2942667:0crwdne2942667:0 197
