The outside casing of the JBL Pulse 3 is the top portion of the device above the speaker grill. In order to take this part off the device, you will need to have removed the speaker grill first. For more information regarding troubleshooting, please visit our Troubleshooting Page.
Lay the JBL Pulse 3 on its side as shown in the picture.
Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
Repeat step 1 for bottom right corner of speaker grill.
After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
Lift and pull straight out to pull grill off the posts.
Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
Pull off the top disc of the JBL Pulse 3.
Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
Wherr can I get or buy top ring for Pulse 3?
Please see our device page with the link to the manufacturer’s website. You should be able to find it there.
I have one of these speakers, and as the delicate outer shell broke it seems nearly impossible to find a replacement…
Any chance to get spare parts in Europe? Thank you.
